chrisinsocalif
Hello,
I know very little about IPv6. I activated IPv6 with time warner and it works. The only caveat I have is when I do a test it gets a score of 17/20. One of the problems is that that Time Warner does not have a reverse DNS record. I know this isn't under my control. What is this and how does it impact my network? The second issue from the test is saying:
Second, I use T-mobile. When I try to use OpenVPN over mobile, it seems to have connectivity issues with IPv6. The OpenVPN app for android states it supports IPv6. It connects no problem over wifi. Is there a way I can overcome this? I can change my phone to IPv4, but hope I can workaround that issue. Can another app work in place of OpenVPN? The log says " MULTI_sva: pool returned IPv4=10.8.0.2, IPv6=(Not enabled)" so could that be the issue? What other information can I supply?
thank you for any input.
Chris
Fyi I am using Merlin's 380.57 on an AC88U.
I do not know if that is good, bad, or if I should change something. Again, what is this and how does it impact my network?Your router or firewall is filtering ICMPv6 messages sent to your computer. An IPv6 host that cannot receive ICMP messages may encounter problems like some web pages loading partially or not at all.
Chris
