GS-AX5400 Wifi Question
Roca68
Hi, Just wondering if it is normal for the 5Ghz Wifi Channel to take 1 to 2 minutes longer than the 2.4Ghz to show up to connect to after a reboot? I have 2 of these in a mesh and am wondering if I have a defective one or not. Thanks.
Welcome to the forums @Roca68.
Yes, it is normal. Particularly if you're using DFS channels and/or Auto Control Channel ranges. Up to 10 minutes or more, depending on your WiFi and non-WiFi interference in your local environment.
