[HELP] Asus RT-AC3200 and 5GHz-2 SLOW
iManuB
Greetings to everyone.
Forgive my English.
I bought this Asus RT-AC3200 router. I noticed, though, a "problem" with the second 5GHz (5GHz-2).
Both with iPhone 7 and with Samsung Smart TV (the latter far from the router only about thirty centimeters) I have a low speed.
With the Samsung TV, using Plex, for example, videos are interrupted and are not fluid. If I connect to the first 5GHz (5GHz-1), everything is faster.
I do not understand what it may be. I write from Italy.
I hope it's not an Asus hardware problem.
I hope someone can help me.
Anyone?
Thanks!
The Channel is set to Automatic.
Current Control Channel: 100
___________________________
Also, last night, I turned off the LED control and I was watching a movie via Plex.
Soon after, I saw the Router's LED on and I noticed that it was restarted.
I touched the Router and noticed it was hot. Could it be a too high temperature problem?
Thanks :D
I am posting the channels I can configure in the second 5GHz (5GHz-2)
Sì, Pierino. Grazie! Provo subito.
Per quanto riguarda il Reboot che ho avuto, secondo te, da cosa potrebbe essere dipeso?
It's better if we keep it in English. I don't know why you had a reboot. You did not say anything before.
Yes, Pierino. I'm so sorry for that!
Two days ago, I turned off the LED control and I was watching a movie via Plex.
