Thorgear
Hi all.
I'm new to Tomato, and somewhat new to router config. I'm trying to setup what I believe is called a downstream router. I have a fairly standard gateway box running Merlin that provides NAT, DCHP, etc. I want to use a Tomato box for QOS. For reasons to annoying to mention, I can't convert the gateway to Tomato.
I'd like to go from the gateway to the Tomato box, then out to the LAN. I assume I need to go into the WAN side of the Tomato box to get QOS. I'd also like DHCP to pass through the Tomato box and provide DHCP for the LAN-side clients - everything on 10.0.1.0/24.
When I put Tomato in router mode, I can't get through the box.
Any suggestions? I'm open to any configurations that keep the gateway in place and running Merlin.
