How do I automate these two commands with merlin software please?
jonnyc55
Hello,
What is the procedure please, to automate these two commands with merlin software so it runs every router restart:
  1. killall mcpd
  2. service stop_amas_lldpd
Is there any issues with these commands, am I ok to do this, if I don't use multicast applications, like file sharing, screen sharing? Thank you!
EDIT: "ASUS Cronjob Deleted After Reboot - Easy Fix"
is the only way,it regards cron jobs, WIN SCP and init-start? Thanks.
Add the commands to /jffs/scripts/services-start to ensure they have already started before you try to kill/stop them.
No opinion on whether it’s a good idea or not.
Ok thank you.
In that file, how is the command of say, killall mcpd written out? Thanks.
