Hey Everyone,
I’m pretty new to customizing Asuswrt-Merlin so bear with me. My main goal is to be able to send AT commands to my 5G modem remotely that is connected to my router WAN port. So far I have DDNS setup so I can log into the web ui remotely but I have yet to figure 2 things I need to do to accomplish my goal.
First I need to be able access the modem via udp from the CLI. As of now I do this while on my home network either from MAC terminal or iOS/ipad app called ish using the Linux command “nc -u 192.168.100.1 5555”. I’ve tried to use this same command through ssh but I’m not sure if that’s the correct way or if I need to do something else first?
Second I need access to the CLI from the Web UI. Is this possible to add via addons? Thanks for any help you can provide.
