How do I install Kamoj on orbi
ComputerSteve
First of all thanks @Voxel for your wonderful firmware. 2 things.. I can't install @kamoj Add-On. I try but I keep getting
/opt/bin/opkg install --force-overwrite kamoj-addon_191214-083737-
1_r9000.ipx
Unknown package 'kamoj-addon_191214-083737-1_r9000.ipx'.
Collected errors:
* opkg_install_cmd: Cannot install package kamoj-addon_191214-083737-1_r9000.ipx.
I also tried:::
1_ipq806x.ipk
Unknown package 'kamoj-addon'.
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for kamoj-addon found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package kamoj-addon.
Any help would be appreciated.. I also cant run /bin/opkg.. I need to type /opt/bin/opkg
1_r9000.ipx
Collected errors:
I also tried:::
1_ipq806x.ipk
Collected errors:
The FAQ at https://voxel-firmware.com/Downloads/Voxel/Kamoj/FAQ.txt, dated 5/1/2021, specifically mentions R7800 and R9000 routers. It is not available for Orbi routers.
I've asked the same question to @kamoj a while ago. Orbi isn't supported and it's not a priority for him.... Not to mention that he doesn't have one. If you want it to work you'll need to take a deep look at each script. Based on my chat with him, he doesn't seem very optimistic that it will work on Orbi out of the box and many things might never work.
If you are planning to dissect the Kamoj add-on and try to make it work on Orbi I would be interested in helping. I am mostly looking for the bandwidth monitoring.
