White_Knight
Hello To All,
Today i first time compile FW image from github, compilation proccess ended after archiving image into .trx file with FW.
How i can check, compillation process run? with out any errors or not ?
I find some log files in image directory (with compilled FW ) named output2.txt, output3.txt, dict_prep.txt and dictenum.txt.
As i understend log files dict_prep.txt and dictenum.txt show language files compilation process
In file named output2.txt i see:
.... ( repeat "Dict no found file..." strings upper ) .....
That Normal situation or not ?
in file output3.txt:
that normal ?
has additional log files ?
General question of this topic, How i can check compilled FW image before uploading to my HW by logs or txt files ?
Sorry if that question is asket before, please point to correct Thread and close this topic
dict no found : /home/user/asuswrt-merlin/release/src-rt-6.x/router/mipsel-uclibc/install/www/www/Advanced_PerformanceTuning_Content.asp , PerformaceTuning_desc
HTML file : /home/user/asuswrt-merlin/release/src-rt-6.x/router/mipsel-uclibc/install/www/www/Advanced_FirmwareUpgrade_Content.asp
HTML_PREP_ELSE no found
HTML_PREP_END no found
Done!
HTML file : /home/user/asuswrt-merlin/release/src-rt-6.x/router/mipsel-uclibc/install/www/www/Advanced_IPTV_Content.asp
Done!
