How to install YAMon / bwmon on Asuswrt-Merlin ?
@ExtremeFiretop
already did that
but there's something that made it work for me
Recreate the index.html, a quick fix to load the React dashboard
cat <<EOF > /opt/share/www/bwmon/index.html
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8" />
<title>BWMON Dashboard</title>
<link rel="icon" href="favicon.ico" />
<link rel="manifest" href="manifest.json" />
</head>
<body>
<noscript>You need to enable JavaScript to run this app.</noscript>
<div id="root"></div>
<script src="static/js/main.77229403.js"></script>
</body>
</html>
EOF
then
/opt/etc/init.d/S80lighttpd restart
I'm glad that something has finally worked, man thank your very much 🍀
can this script be viewed through WAN like Asus router dashboard because it doesn't!
@ExtremeFiretop
already did that
then
I'm not sure why the index.html would need to be recreated/missing, but happy you got it working.
I submitted a PR to the devs with some suggested fixes: https://github.com/VREMSoftwareDevelopment/bwmon/pull/99
Hello ExtremeFiretop and good day! Expertise/instructions for installing lighttpd/bwmon appreciated, excellent tool, and I'm now accessing GUI thruput statistics for my system. :)
Is it possible to export /tmp/mnt/usb1/entware/share/bwmon/bwmonUsage.db (database storing bwmon GUI data??) to an external (maria?) database? My goal is to extract hourly, daily, weekly, and monthly statistics reports via scripts.
Thanks,
Danny
Thanks,
Danny
I think you might want to check this
SkyHero Monitor
