Installing Entware?
How does one? I cannot find any guide that really explains things.
I get this error:
*** Error: No ext2|ext3|ext4 partitions available. Exiting...
So I need a external USB? Which I already have for traffic saving. How can I see a path?
Sorry new to entware. Just wanting to use this: https://www.snbforums.com/threads/connmon-internet-connection-monitoring.56163/
Thanks!
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
Yes, an external USB drive is required.
I'm almost 100% sure you'll be using other scripts soon, so I recommend you use and follow the guide linked above.
Please start at the beginning and take things step-by-step to get a reliable, working environment. :)
Thanks!
Stuck though here:
" Type '/jffs/scripts/amtm' without the quotes and hit Enter
  1. using amtm, install Entware
  2. Wait for Entware install to be completed
  3. Optionally, if Diversion is also required,
    1. Install Diversion (Lite) and it will properly install Entware or
    2. Install Diversion (Standard) and it will properly install Entware and pixelserv-tls too"
Its not telling me the command on installing entware
Thanks!
Stuck though here:
Just follow the guide. It will get it all installed for you. ;)
I am :)
amtm is installed, but the part of the guide that says Entware it gives no commands for installing it lol. This is all its giving.
EDIT: ahh I see now, the guide doesnt say press I for the install menu lol
I am :)
That was a recent addition when amtm was upgraded.
If you want to use Diversion, install it instead. It will also (optionally, you can choose it then) install Entware for you.
You can even do the Diversion install and then disable it (for now) and you will still have Entware installed. :)
Thanks again!
Any addons related to BW watching/monitoring?
Thanks once again :)
