Hello All,
I have Asus AC-68u w/ 378.55. And, I restart my router every night with a cronjob. But, during the day, what I am experiencing is that after some certain amount of time (couple of hours), Internet is slowing down to a grinding halt. Google ping times are slowing down x3 times or so, bandwidth is dropping to between 1/5th and 1/6th of normal.
And, I have one at work (same router w/ 378.55), and that is even worse where I loose the Internet connection completely (cannot ping google from connected devices or even from the router via ssh).
BTW, internal network is completely fine, I can connect to the router or anything on LAN. I am just having problems w/ the internet connection.
And, weird thing is that, restarting the router is restoring the speeds / connectivity immediately, literally right after a restart, speed is resumed to normal values.
I tried looking at syslog, but not seeing anything valuable. And, I am quite desperate at this point, since I need to keep restarting the router every couple of hours...
As a side note, I am not running anything special on the router like IP traffic logging, or DLNA, or advanced QoS or torrent or anything that might be a resource hog.
Can you please recommend what I should be looking at and/or how can diagnose this issue?
Thanks a ton.
Thanks a ton.
