IPSET rule keeps disappearing on AC68U
peraburek
Hello,
I am running Merlin Firmware Version: 384.18 on RT-AC68U
I want to allow only IPs from UptimeDoctor in order to check my Internet Connection every 60 seconds (1 minute interval) using ICMP (ping)
here is script I am using /jffs/scripts/ddns-start
#!/bin/sh
#whitelist uptimedoctor IPv4 for ICMP
curl https://www.uptimedoctor.com/de/network.php?type=xml > /mnt/sda1/router/uptimedoctor-raw.txt
cat /mnt/sda1/router/uptimedoctor-raw.txt | grep -oE '((1?[0-9][0-9]?|2[0-4][0-9]|25[0-5])\.){3}(1?[0-9][0-9]?|2[0-4][0-9]|25[0-5])' > /mnt/sda1/router/uptimedoctor-ipv4.txt
sed -i -e 's/^/add uptimedoctor /' /mnt/sda1/router/uptimedoctor-ipv4.txt
if (ipset list | grep -c uptimedoctor)
#if the keyword is in the conent
then
echo "ipset list uptimedoctor found"
else
ipset create uptimedoctor hash:ip
fi
ipset restore -! < /mnt/sda1/router/uptimedoctor-ipv4.txt
if (iptables -nL | grep -c uptimedoctor)
then
echo "uptimedoctor found in iptables"
else
iptables -I INPUT -p icmp -m set --match-set uptimedoctor src -j ACCEPT
fi
#remove iptables rule and delete uptimedoctor ipset
#iptables -D INPUT -p icmp -m set --match-set uptimedoctor src -j ACCEPT
#ipset destroy uptimedoctor
Do you have any idea, why this rule keeps disappearing from iptables, it seems that router is deleting this ipset list on its own, for no reason?
Suggestions are welcome, in order to improve script and get this working stable. Thank you!
Why is it in ddns-start? It would be better in firewall-start.
since I use DNS-O-Matic, I thought ddns-start would be OK place to store ipset commands
I have renamed/moved file
from /jffs/scripts/ddns-start
to /jffs/scripts/firewall-start
I will report here if it makes any improvement, thank you for sharing your idea!
Maybe store the downloaded file in /tmp or /jffs so it is not dependent on your USB drive.
you are right, it could be that router doesn't mount USB drive fast enough...
I will adjust script (path) and move files to /jffs folder
