RT-AX86U Nord VPN client keeps getting disconnected
zillah
Hi All
My router is RT-AX86U with firmware version 388.2_2
I am using a paid NordVPN ,,,,everything working fine but between time to time the service state toggle witch keeps turning off as per attached snapshot below :
Did you upload its .opvn configuration file or did you input the parameters manually? Furthermore, you can look at the router syslog, which may explain why the VPN could not be connected.
Agree with @Quoc Huynh above... take a look at the logs. It could be retrying to connect, but then gives up after so many attempts, and turns off. Sometimes servers go down, become unreachable, or Nord puts them through maintenance... afraid this happens all the time.
This is one of those reasons I built VPNMON-R2... give it shot if you're looking for a more stable VPN connection.
Thx guys
Nord VPN gets connected and i had upload a file not manual configuration.
But issue every 10 days or so that switch gets shut off automatically , what i have been doing i have manually to turn it on again for the VPN to work
Thx guys
Unless you add some automation (like a script), you will likely continue to have to do this.
