Is Merlin slower than stock for browsing?
brummygit
I've been running Asuswrt-Merlin on my RT-AC68U and recently gave the Asus stock firmware 378_9135 a try. Having switched back to Merlin's latest beta I'm finding that Merlin is much slower for web browsing.
I don't have any issues getting my maximum bandwidth (around 70Mbps down and 20Mbps up) but what I notice is the speed at which web pages are displayed. This is almost as if its a dns performance problem.
My config (both start from a factory reset) uses the ASUS Adaptive QoS and AiProtection in both and on stock I configure OpenDNS as my WAN DNS manually whereas on Merlin I like to use the DNS filtering option which gives me granular control.
Is it normal that Merlin should be noticeably slower, or am I likely to have some form of issue?
I have a 150/15 MBit line and full speed with Merlin firmware on browsing. :rolleyes:
After switching firmware, you need to do a factory reset and start a fresh configuration (or use the NVRAM Save/Restore utility to save and restore the user settings after factory reset).
Do a manual minimum configuration and test before you add USB drive or AICloud functionality.
With kind regards
Joe :cool:
If you enable the same features as you do under stock, then the performance should be identical.
Thank you RMerlin. The only major difference in my configurations is DNS Filtering - are you aware of any significant performance differences that this would introduce?
In the stock FW I configure OpenDNS as my WAN DNS manually whereas on Merlin I like to use the DNS filtering option to enforce the same OpenDNS servers as this gives me granular control if I want it, and more importantly enforces the use of my preferred DNS.
Is the computer you're testing from also going through OpenDNS?
When you plug in the servers as the WAN DNS the router will act as a DNS cache for the OpenDNS requests via dnsmasq. When you use DNS filtering, the requests are not cached and all requests get directed to the OpenDNS servers.
