Frequentflyer
I got my DS207+ setup tonight and I'm having problems mapping the drive. It seems to be giving me the same problem my Central Axis was giving me, so I'm under the assumption this is a Windows issue and not the drive. The Synology setup was quite simple and everything seemed to go smoothly following the Synology instructions/software. I have the drives setup in RAID1 and I updated to the latest Firmware. I currently have two wired desktops on the network connected to a D-Link 2205 "green" gigabit switch. One desktop is running Vista 64 and the other is running XP SP3. With both desktops and the DiskStation assigned to the same workgroup, I cannot see either the DS or the XP machine on the Vista machine. However, I can see the DiskStation on the XP machine (but can't see the Vista machine on the XP machine). I really don't care if I can share files amongst the desktops, but I do care about being able to see the DiskStation from the Vista machine, as that is my primary computer. I cannot figure out why I'm seeing it on the XP machine and not the Vista machine, which is the one I installed the Synology software on. I can connect to the DS via internet explorer through the Vista machine and the Synology Assistant shows the drive. I currently have it set to a static address vs. DHCP. I created a shared folder on the drive after it sync'd the RAID1 setup and when I go to map it on the Vista machine it tells me it cannot connect to the server. On the Vista machine, all it shows in the workgroup is itself and the router, that's it. Any thoughts?
