kernel warning msg w.r.t. hdd
Sean Nelson
AC68u, currently 380.69_2 but issue existed with earlier versions as well.
I have a 2TB Toshiba USB3.0 portable HDD connected to the router. It works fine (all supported protocols). But from time to time system log shows:
Mar 17 10:55:01 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
and
Mar 17 10:57:40 kernel: htb: htb qdisc 12: is non-work-conserving?
I set my log to be above "info", and the first kind of msg makes up 99% of my log (it usually comes in bursts of several dozen a time); the second kind is less frequent but also persistent. Also they seem to show up at random time -- not necessarily when someone actively accesses the disk.
The disk performance seems fine in terms of both latency and throughput, so these warnings are not causing any trouble, but I am curious about them. I suppose the HDD has some sort of power saving function; would that be a cause?
Sean
and
Sean
The second error is not actually an error it is an indication that you use QOS and it is working. The first message you will need someone smarter than me.
updated to 384.4 and the message remains. Tons of it, as before.
It seems that other people who saw this message tend to have problem accessing the usb drive (and with other error messages); So far I have not had access problems.
To me the message looks like the HDD is powering down, which is pretty typical behaviour for a "portable" HDD. If you've got things setup so that the HDD is intermittently accessed then you could see this a lot as the drive constantly sleeps and wakes. That's why portable HDD's are not a good choice for "NAS-type" setups.
Sometimes the HDD comes with a utility that allows you to turn off the power-saving features. Alternatively, some filesystems like ext4 are constantly updating their journal so that prevents the drive from ever sleeping (depending on the precise intervals).
