Latest Merlin firmware wireless N 200mbps
Rob Nellen
Hi guys
I have an Asus Rt-AC68U and currently have version 378.54_2 firmware installed on it. I have a raspberry pi 2 with a wireless AC adaptor but because of compatibility issues I have to run the adaptor on 5GHZ wireless N at 150mbps. Anything above this (AC) causes the wireless to drop out and makes it unusable.
The problem I have is with the latest firmwares the 5GHZ wireless N speed is now at 200mbps and causes the adaptor to drop out. I have had to roll back a couple of times after trying various firmwares. Is there a way to cap the speed at which the adaptor connects to the wireless? Either AC or N 150mbps?
Many thanks
You could try 20Mhz channel bandwidth. It dropped my speed to 195. My adapter has 3 antennas I assume your bandwidth will be less since yours have less than 3.
Thanks snakebite
I think I have tried that and it still took it over 150Mbps. I will have another go though when I get home tonight. Is it because of the driver version that the speed has now increased with the latest firmware?
Cheers
Thanks snakebite
Cheers
Try the older firmware if you think this lastest causes the speed to increase. I haven't my notice my wi-fi improving.
Are you the only one using the router? There's no other solution for your wi-fi adapter issue? It seems wasteful to cripple your router.
