MerlinAU MerlinAU v1.5.7 - The Ultimate Firmware Auto-Updater (WEBUI + GNUTON SUPPORT!)
Question on why F/W Update Postponement Days was not honored after the MerlinAU update to 1.5.1.
All my routers either updated or tried to update to 3004.388.9.2-gnuton2 from 3004.388.9.2-gnuton1.
I currently have all routers set to 30 days.
4. Set F/W Update Postponement Days
[Current Days: 30]
Also the last notification date didn't get updated.
3. Toggle Automatic F/W Update Checks
[Currently ENABLED ]
[Last Notification Date: 2025-Jun-25 12:20 AM]
That date is from when 3004.388.9.2-gnuton1 became available.
What does this mean? They will always "try" to update... Everyday (or however often you setup the cron schedule)
But will be blocked by the postpone until it's been passed. Can you provide logs of the update attempt from the "Log Options" menu please? What about router models or screenshots?
I just tested this report on my Gnuton router and got the expected behavior both interactively and non-interactively and was unable to replicate:
Again unable to recreate this. Please provide logs, models, and any screenshots of the issue.
Thanks!
Also to be clear in your case, I believe the issue is actually only that the last notification date didn't get updated,
Not that the postpone was not honored. In-fact in your case the postpone appears was perfectly honored. 30 days away from your last notification date would be July 25, so the 30 days are long past by that point and the postpone has nothing to block.
But the notification date should of updated from gnuton1 to gnuton2 and reset the postpone period, which in this case it doesn't look like it did for some reason. What is your cron schedule set as?
I'm assuming because up until 1.5.1 both MerlinAU and the built-in Webs_update script was were unable to determine that Gnuton2 is newer than Gnuton1.
MerlinAU is manually working around that issue until @GNUton merges in PR: https://github.com/gnuton/asuswrt-merlin.ng/pull/813
View attachment 67161View attachment 67162
Thanks!
I have one ax92u that tried to update FW but was unable due to memory available. I updated this one after a reboot using the GUI.
Also there are three xt8's that updated from MelrinAU. Here is the update log from one of these units.
I believe you are correct that the issue was due to the notification date not being updated. The date it currently has is from when the F/W
3004.388.9.2-gnuton1 was released. At that time it did what I was expecting. Sent a email of new F/W version but did not update F/W.
All of my routers have the same notification date of June 25. None were updated from this mornings F/W updates.
Attached is the cron from one of the XT8's.
Okay thanks for that, the extra detail helps shape a picture. The script at this point is over 11,000 lines of code so going off memory these days isn't always possible.
I have a theory, let me see if I can recreate it/confirm it. I'll message you shortly if I need anything else from you.
I don't see anything that catches my eye but here is the messages file from first entry after midnight till reboot after F/W update.
Hi @scootertramp
Just circling back around to confirm I've replicated your behavior, thank you for reporting it and providing the extremely useful log data as i was unable to replicate it originally.
The issue as I thought is the fact that your settings file still contained the older formatted version for Gnuton as seen below.
-Postpone "Bypassed"
-Postpone working as designed:
It would only be an issue for Gnuton users, and only an issue for users jumping from 1.5.0 to 1.5.1 with our current state of having 2 identical releases from Gnuton: 3004.388.9_2-gnuton1 and 3004.388.9_2-gnuton2
I won't lie; this is 120% an oversight on my part with MerlinAU release v1.5.1 where I fixed the Gnuton version comparisons in PR: https://github.com/ExtremeFiretop/MerlinAutoUpdate-Router/pull/498
To quote mydumbself:
PR: [ #498 ] - Fixing More Comparison Errors
  • Turns out we can't strip -gnuton1 or -gnuton2 as those actually mean something LOL I had to pivot so we correctly weighted those suffixes, and then go back and redo the fixes for the 2 previous PRs and think real hard to make sure there's no backlash and I don't retrigger those problems
Well; clearly I didn't think hard enough LOL.
It would "fix itself" and start to use the "long version" of the firmware version when the next firmware release actually increments itself (i.e 3004.388.9_3 or 3004.389.0?)
However that's not something I'm okay ignoring so I've created PR: https://github.com/ExtremeFiretop/MerlinAutoUpdate-Router/pull/505
It resolved the issue for me in my test after re-creating the issue, and the change is so small I was tempted to just push it through... But I think it's in everyone's interest I let Martinski test on his non-Gnuton routers as well to sign off on the next release.
Thanks again for the fun investigation!
If “Toggle Automatic F/W Update Checks” is disabled but you manually run “Run F/W Update Check Now”, should it be able to find the updated firmware? I am on 3004.388.8.4 and have had automatic F/W update checks disabled for a while due to traveling and running the manual check resulted in no FW updates being found. Once I re-enabled the automatic check it found the updated firmware 3006.102.5.0 without any issue.
No, without the built in update check enabled, it will never find an available update. This is by design as that toggle is literally a hard on or off for the entire system. Even if you try manually, once it's disabled it will never find anything.
MerlinAU 1.5.2 Released!
What's Changed/Fixed?:
PR: [ #505 ] - Fix Reported Gnuton Comparison Errors
PR: [ #506 ] - Minor cleanup
As always, we highly recommend you update ASAP as this includes functional improvements and little bug fixes.
Thanks!
I updated via the web UI this morning, and I noticed a minor cosmetic nit, which has probably been long-standing as I usually update either via auto update or CLI: when the update completes, the version number at the top of the web page is not updated until I refresh the browser.
I will have to admit, I was skeptical at first, but this is one of the most robust utilities ever implemented to auto update firmware! It has saved me hours of time for routers and nodes that "refuse" to apply manually initiated updates for whatever reason. @ExtremeFiretop and @Martinski, you make an awesome team.
Wholeheartedly agree with @visortgw! This tool has been outstanding. Amazing work on this, @ExtremeFiretop & @Martinski!
I don't really need to add to the sentiment........... but
We've gone from everyone saying it can't be done to something people just trust and leave to it's job.
Hat's off to your tenacity
@Ripshod @visortgw @Viktor Jaep
All of you are truly too kind. And I think I've got to know @Martinski well enough to say it for the both of us. 😉
The truth is, as long as the tool saves you time and energy; it's doing its job!
I don't care if it's 10 minutes or 5 seconds a month, if you can be that much more hands off and just trust that it will happen safely then it's an accomplishment for me and a job well done.
It was always something I thought was missing from RMerlins firmware; and since the introduction of this tool, worrying about firmware updates is a thing of the past for me.
Now instead I get to focus my time on the other projects you guys put me on! 😂
I just saw mention in a different thread that MerlinAU can show info about an AiMesh node. I can't figure out how/where to view this. Can you provide some extra details? Both nodes are running Merlin and MerlinAU. Thanks!
Option MN from the opening menu, see below
What it looks like
But from the router, if running MerlinAU on the node the MN opption does not appear on the node, see below
At least for me this is the case...
Note: From the command line/SSH, not in the GUI...
And, if an AiMesh node is running Merlin firmware, you can install MerlinAU on the node as well.
The AiMesh menu will even correctly detect stock firmware on the nodes, but will never actually display any updates for them if they are stock, since MerlinAU only recognizes merlin firmware and only has access to Merlin repo.
Ideally the entire network is running Merlin firmware which is how I've always run my network. I realize some like the newest GPL for nodes and will swap back and forth back to stock if the GPL is newer than Merlin. But I've just found it easier to do all Merlin, and let MerlinAU keep my nodes updated.
Yeah, that is how MerlinAU works as currently implemented; however, after some thinking, I believe there are good reasons for allowing users to request a *manual* F/W update check via the menu option even when *automatic* F/W update checks are disabled.
If on-demand F/W update checks are allowed whenever users manually run the script and select the menu option, they would get the requested information and may proceed if a new F/W version update is found available. All this would happen without the need to re-enable the built-in, system-wide "Automatic F/W Update Checks" functionality.
Users like @vlord who prefer to have "Automatic F/W Update Checks" disabled due to travel or other personal commitments/situations and are not always available at home to monitor automatic F/W updates, could instead run *manual* F/W update checks while the automatic functionality remains disabled.
I'll submit shortly a PR with the necessary changes.
UPDATE:
Pull Request #508 has been submitted to the 'development' branch.
