MerlinAU MerlinAU v1.5.7 - The Ultimate Firmware Auto-Updater (WEBUI + GNUTON SUPPORT!)
MerlinAU 1.5.4 Released!
What's Changed/Fixed?:
PR: [ #515 ] - Fixes and Improvements for Modifying Cron Jobs
  • Fixed bug when checking and modifying the cron job to schedule the Automatic F/W Updates checks.
  • Improved code when checking and modifying the cron job to schedule the Automatic Script Update checks.
  • (Thanks @Martinski4GitHub )
As always, we highly recommend you update ASAP as this includes functional improvements and little bug fixes.
Thanks!
I have a feature request, if possible - would love to see an option to skip a single selected firmware version update.
I, like some others here, have issues with wifi network (some devices not willing to connect) on 3006.102.15 while everything is fine on .14.
I've downgraded to .14 just to find out the script updated to .15 the next night (even if I have 7 days delay set up).
It would be nice to be able to skip certain version (currently offered as the latest) until the next one is published.
Simply disable auto updates in the script. Or set a longer postpone period.
Thanks for using the script!
on the MerlinAU user asp page, the firmware check button never finds an update if "Enable Automatic F/W Update Checks" is turned off.
Manual update check by ssh finds the new firmware and offers to install it as usual.
Thank you for this report. I always appreciate when users identify points of friction in the code which can be improved.
Unfortunately I am still away for now, to be specific, I'm about to jump on a plane for my vacation in Cancun.
In the meantime, I'll recruit my good friend @Martinski to look into this one and validate this behavior, and pump out an update as needed.
If anything is required from me, I expect to be back at my desk doing AMTM-OSR and MerlinAU business by the 2nd week of November.
Enjoy your well-deserved vacation. Have a drink for each of us... 🤣
You better not be checking your email from Cancun! Hope you get LOTS of rest and relaxation! :)
Great catch!! Thank you for reporting the issue. This is now fixed in the latest development 1.5.5_25110200 version now available.
If you'd like to test and verify the fix, you can switch from the current production release to the latest development version using the following command:
Bash:
/jffs/scripts/MerlinAU.sh develop
Doing the best I can! One drink at the beach for each like that post got so far 😁
Nooooo emails being checked! but I do pickup my phone once in a while, I figured I'd stop by and mention how nice the sand feels between my toes. 😂
I'm shipping off a release as it seems@Martinski fixed it in development, but left a PR hanging without merging to production. He's too nice to merge it in without my review, even though he's got full rights to my repo 🤣😉
MerlinAU 1.5.5 Released!
PR: [ #524 ] - Fix and Cleanup
FIXED: On the WebUI page, clicking on the "F/W Update Check" button did not trigger an update check unless "Enable Automatic F/W Update Checks" was also activated.
Reported by @Squall Leonhart
PR: [ #521 ] - Removed Tomato JS References
CLEANUP: Removed old Tomato JavaScript file references.
No Tomato JS functions were actually used.
That is all! As always, we highly recommend you update ASAP as this includes functional improvements and little bug fixes.
Thanks!
Thanks!
Publishing a release from the beach in another country with a cold margarita in your hand?? Bravo, sir! Bravo!! 👏😋
Release Notes for MerlinAU v1.5.6 production version now available
[2025-Nov-08]
1) PR #525 - Fix for "parameter not set" Error
FIXED: A bug was generating a "currentDIVER_version: parameter not set" error message.​
This error happened when trying to flash the F/W image, and Diversion is installed, but logging into the router WebUI failed for any reason.​
[2025-Nov-08]
When I try logging into the router web page and enter my username and password I get an error message incorrect username/passwod.
I have tried filling the username/password from Bitwarde password manager and manual entry a few times now without sucsess.
I have just upgraded from MerlinAU v1.5.5 to v1.5.6 and when I look into MerlinAu from amtm
2. Set Router Login Password
[Currently Password is verified.]
So why can't I log into the asus web page?
Also my password is 9 characters long but MerlinAU say
[Length=10]: **********
When entering the password via SSH you can view/hide the password by using the "TAB" key.
My question is when using the "TAB" key, does the password appear to be entered as expected/correctly? Manually validating the password value will help us better understand what is happening.
Can you confirm your only entering your password? The username isn't a value you should need to enter, it comes from nvram on the router.
Does this command provide you with the correct username when entering via SSH? "nvram get http_username"
I don't think this is related to MERLINAU as the poster can't login to the main router gui, as they have posted elsewhere.
@pedeb04 I think you need to reset your router and start again.
Thanks Ripshod, I was about to start from the beginning with ExtremeFiretop.
I had just posted about not being able to login to the main router gui when I got a notification about an update to MerlinAU v1.5.5. I thought MerlinAU could be the issue so I updated to v1.5.6 but this did not remedy the situation.
When I went into the MerlinAU menu I noticed it said password is verified, and if I went into change password it said my current password is length=10 when my password is only 9 characters. So I thought the MerlinAU update could be the problem.
If it is not I don't understand as I have not changed my router password!!!
Just wandering as Backupmon does a daily backup of my router settings, could I revert to an earlier setting as a solution?
Not sure if it backs up password.
Just really frustrated how the password could have changed.
