miniupnpd[5545]: No allowed eport for NAT-PMP 37370 udp
Asus 1967
Hello,
I have rt-ac88u 384.5 and have noticed I am getting this entry in the log file very frequently
I am not sure what this means. I have tried to search this and would appreciate any info
Thank You
The last part of the error message appears to be missing. It gives an IP address and port number. Knowing that will tell use the problem.
Thank you
Jun 27 22:51:28 miniupnpd[5545]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jun 27 23:06:31 miniupnpd[5545]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jun 27 23:21:34 miniupnpd[5545]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jun 27 23:36:37 miniupnpd[5545]: No allowed eport for NAT-PMP 37370 udp->19
What is the device at 192.168.1.137? Something is trying to setup a port forward to that device but the router is not allowing it because the port is <1024. My guess is it is something trying to do wake-on-lan.
It's trying to forward port 9, however by default only ports 1024-65535 are allowed.
Appreciate the help. Is there a process I can follow to tell me which device and app is making the request.
Thank You
Do you have any software installed (either on the PC or any other device) that provides a WoL function?
Thanks Colin, I'm not sure, the request repeats every 15 minutes.
Jul 7 21:48:03 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.230:9
Jul 7 21:53:28 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jul 7 22:03:06 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.230:9
Jul 7 22:08:31 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jul 7 22:18:09 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.230:9
Jul 7 22:23:34 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jul 7 22:33:13 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.230:9
Jul 7 22:38:37 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
Jul 7 22:48:16 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.230:9
Jul 7 22:53:40 miniupnpd[3049]: No allowed eport for NAT-PMP 37370 udp->192.168.1.137:9
the address .137 is a desktop and .230 is my laptop. Could this be coming from my network printer?
Could you issue the following command on the desktop and laptop. It will show us whether there is actually something listening on port 9.
C:\Users\Colin>netstat -ap udp
Active Connections
  Proto  Local Address          Foreign Address        State
  UDP    0.0.0.0:500            *:*
  UDP    0.0.0.0:3702           *:*
  UDP    0.0.0.0:4500           *:*
  UDP    0.0.0.0:5353           *:*
  UDP    0.0.0.0:5355           *:*
  UDP    0.0.0.0:53202          *:*
  UDP    0.0.0.0:59906          *:*
  UDP    0.0.0.0:59908          *:*
  UDP    0.0.0.0:59910          *:*
  UDP    0.0.0.0:62190          *:*
  UDP    0.0.0.0:63125          *:*
  UDP    127.0.0.1:1900         *:*
  UDP    127.0.0.1:53674        *:*
  UDP    192.168.1.238:137      *:*
  UDP    192.168.1.238:138      *:*
  UDP    192.168.1.238:1900     *:*
  UDP    192.168.1.238:53673    *:*
this is what came back:
UDP 0.0.0.0:500 *:*
UDP 0.0.0.0:5004 *:*
UDP 0.0.0.0:5005 *:*
UDP 0.0.0.0:5050 *:*
UDP 0.0.0.0:6783 *:*
UDP 0.0.0.0:49954 *:*
UDP 0.0.0.0:49955 *:*
UDP 0.0.0.0:49956 *:*
UDP 0.0.0.0:49957 *:*
UDP 0.0.0.0:49958 *:*
UDP 0.0.0.0:49959 *:*
UDP 0.0.0.0:50538 *:*
UDP 0.0.0.0:52820 *:*
UDP 0.0.0.0:53966 *:*
UDP 0.0.0.0:53967 *:*
UDP 0.0.0.0:53968 *:*
UDP 0.0.0.0:53969 *:*
UDP 0.0.0.0:53970 *:*
UDP 0.0.0.0:53971 *:*
UDP 0.0.0.0:57249 *:*
UDP 0.0.0.0:57255 *:*
UDP 0.0.0.0:57256 *:*
UDP 0.0.0.0:57257 *:*
UDP 0.0.0.0:57258 *:*
UDP 0.0.0.0:57259 *:*
UDP 0.0.0.0:57260 *:*
UDP 0.0.0.0:60857 *:*
UDP 127.0.0.1:49666 *:*
UDP 127.0.0.1:51311 *:*
UDP 127.0.0.1:51312 *:*
UDP 127.0.0.1:53424 *:*
UDP 127.0.0.1:53425 *:*
UDP 127.0.0.1:57251 *:*
UDP 127.0.0.1:57252 *:*
UDP 127.0.0.1:57253 *:*
UDP 127.0.0.1:58537 *:*
UDP 127.0.0.1:58538 *:*
UDP 127.0.0.1:61705 *:*
UDP 127.0.0.1:61706 *:*
UDP 127.0.0.1:63031 *:*
UDP 127.0.0.1:63032 *:*
UDP 127.0.0.1:64200 *:*
UDP 127.0.0.1:64201 *:*
UDP 192.168.1.137:137 *:*
UDP 192.168.1.137:138 *:*
UDP 192.168.1.137:1900 *:*
UDP 192.168.1.137:5353 *:*
UDP 192.168.1.137:49665 *:*
@Asus 1967 I've just had a conversation with @Blaine07 about this error message as he was getting exactly the same thing in his syslog. He has confirmed that the device referenced by the IP address was 'a “bridged” connection on my MacBook Pro that was running a Parallels Virtual Machine'.
So it looks like @john9527's post #11 is correct. Can you confirm this?
