Need advice in manually changing setting for IPTV profiles
fastcx
Hi all,
For my question, recently my customer's office moved to an area that support VOIP for a certain ISP (Unifi Business), but in the IPTV settings, when chooseing that profile it didn't provide voip over lan3 port which is required for it to work. If I don't choose that option, e.g. choosing manual setting, it won't connect to ISP for internet.
So, if you do understand my question, how do I change the preset profile? Is it closed source? Or just login to telnet and set it from there is possible? If it is, which directory I should be looking for and which file to edit? Since I know the VLAN for those ports(Getting those info from ISP provided router, a bloody underpowered router for the speed and traffic this office need).
Thanks in advance!
