mominn8266
Hey guys i need some help. I just upgraded my plan to the 50/20 Fios and now i really want that speed upstairs to my gameroom. Before i had the 10/2 plan where wireless was sufficient (i could get 9mpbs download speed wirelessly everywhere i needed internet using the mi424wr)
But now this crappy (no offense ) router is just not sufficient for the 50mbps download speed. Even if my laptop is RIGHT NEXT to the router, i only get max speed of 20 - 23mpbs download. Whereas if im connected via ethernet, i get the full 50+Mbps download speed. For some reason the upload speed is fine at over 20mpbs. (Anyone has any explanation for this? If other 2.4ghz devices were causing interferences, shouldnt the upload speed be affected also?) And Yes, i have changed the channel to 11 (every other wifi network is on 6)
I also have this hawking high gain antenna connected to the router: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
In any case i feel that MoCa would be a much cheaper and more reliable approach to achieve better speeds compared to buying a wireless n dual band router & adapter
Currently i have the ONT connect to the WAN Router VIA Coax
I also have Dish network for Tv services with the STB upstairs (same room where i want the Ethernet from MoCa to connect to PC,PS3). Not sure if relevent, but the dish is set up so that my downstair tv has acces to Dish tv VIA the coax connected to the STB upstairs. So ONE STB provides TV upstairs AND TV downstairs with dish services via Coax.
There are two jacks for Coax upstairs and only one is in use. I have attached a picture of how it is set up.
From the various articles i have read, this is my understanding of what i should do but of course im a newbie so i need your suggestions. I should add splitter the coax coming out of the ONT and connect one split to the router and the other split to the wall? then upstairs add a splitter to the coax connection from the wall and split one for dish STB and split one for MoCa actiontec which will then be connect to the internet and i could run ethernet from MoCa actiontec to ps3 and PC.
Is that anywhere even close to a working solution or im just dreaming that it would this easy? lol
Thanks for all the help!
