Need help with IPSet
Jay Culley
I am running the script referenced below for IP blocking but I cannot find an example of /jffs/scripts/ipset.txt
Does anyone know where I can find that, the format it needs to be?
ipset script: http://pastebin.com/FasEQ2NE
Sorry for being such a noob.
Have you turned on : Enable JFFS custom scripts and configs
Yes, Jffs enabled. Running a script already to modify vsftpd.conf to enable logging, added firewall rules to firewall-start for Transmission ptp.
Entware installed with mc, iftop, nanao, htop
latest fw 380_64_1
thanks
I expect it will look something like this:
; Spamhaus EDROP List 2017/01/08 - (c) 2017 The Spamhaus Project
; https://www.spamhaus.org/drop/edrop.txt
; Last-Modified: Tue, 15 Nov 2016 14:08:00 GMT
; Expires: Mon, 09 Jan 2017 15:03:49 GMT
27.112.32.0/19 ; SBL237955
37.9.53.0/24 ; SBL273113
41.71.171.0/24 ; SBL260492
41.71.176.0/23 ; SBL260482
41.71.178.0/24 ; SBL260491
41.71.184.0/22 ; SBL260485
You can get ipset to generate one for you with:
ipset save -f ipset.txt
Thanks Nurrophile. ipset gened up an empty file, but that's ok, I just pasted in the data from th Spamhaus link to get started. I cannot mess with the routers until like 2:30 am, couple work from home vpn connections and i just cannot interrupt my teenage daughters lifeline to the world! Going to try to get this going tonight. I am only going to set up ipset on the 5300 core router, the n66 is in AP mode so I just flash it to the latest merlin FW, install entware, tcpdump, nano and then pretty much leave it alone.
