Need help with with wpa supplement
Tgenius
hello! I have an Asus RT86u that I’m trying to get to run the wpa supplement to remove the ATT gateway, I’m following the following steps
https://github.com/bypassrg/att
I’m pretty close to the end however the issue I’m having is the files were compiled for an Rt68u which I believe is arm7 2.6, but my device uses arm7 3.2.
For the life of me I can’t figure out how I’m supposed to compile those 3 files from the source in 3.2? Any help would be greatly appreciated!!
heysoundude
Part of the Furniture
Surely there’s backwards compatibility? It’ll tell you if dependencies are missing.
Tgenius
Unfortunately not. It throws errors saying it’s not compatible with the version I’m running, the 86u is 3.2 and the build of the wpa supplicant is 2.6 so not sure if that’s why it’s not working?
Tgenius
Hello,
Specifically, this is the error thrown when I try to run:
opkg install -d opt libubus_2018-10-06-221ce7e7-1_armv7-2.6.ipk
Unknown package 'libubus'.
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for libubus found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package libubus.
heysoundude
I haven’t looked at the github link you posted, which likely holds clues as to why you’re having troubles.
Tgenius
Thank you for the quick response! The author of the github says you will need to re-compile the supplicant for the correct arm version. There are 3 files in particular that had to be compiled:
opkg install -d opt hostapd-common_2018-12-02-c2c6c01b-6_armv7-2.6.ipk
opkg install -d opt wpa-supplicant_2018-12-02-c2c6c01b-6_armv7-2.6.ipk
As you can see the 3 of them were compiled for armv7-2.6, when my entware version for the RT86u is based off this version of entware:
wget -O - http://bin.entware.net/armv7sf-k3.2/installer/generic.sh | sh
I'm not a programmer in the slightest so I'm stuck :(
heysoundude
As I understand it, the rt-ac86u is based on kernel 4.1x. Something may have replaced the package/dependency over the span of the kernel upgrades.
You’re going to have to dig deeper, I’m afraid.
Tgenius
Ok, that makes sense. Who would be a good resource to ask about that, or perhaps the correct way for me to ask it, so it makes sense? I appreciate immensely the responses though!
heysoundude
Perhaps you can go back to the resource that pointed you to this one on GitHub and see if anyone there has advice for you. There might be a much better, easier, sexier way of doing what you want to accomplish
EDIT:
read this page https://github.com/bypassrg/att/blob/master/README.md
the author specifically states you have to let them know if it doesn't work, so you'll need to reach out. do you have a github account? I'll bet they walk you through the setup themselves. It's usually always a very small oversight that gums up the works.
RMerlin
Asuswrt-Merlin dev
The default Entware install for the RT-AC86U is armv8 64-bit (or aarch64). Make sure you aren't trying to mix components that are armv7 32-bit with armv8 64-bit.
Tgenius
RMerlin,
Thanks for the input. I'm basing everything on the Entware armv7 to go along with the instructions provided by bypassrg on the github. He mentions that if your using a different router than the RT-AC68u (which is 2.6 I believe) that you need to recompile for the version that corresponds to you. I have no clue how to recompile the wpa supplicant he apparently created based on 2.6. What would I need to do? I tried looking at the packages list for the armv7 3.2 and didn't find any of the 3 files that had been compiled.
Actually if I could get the files and go the way of aarch64 i would go that route too. He mentioned also something about the wpa supplicant being too old on the build which is why he had to update it or something along those lines?
RMerlin
Asuswrt-Merlin dev
I don't know, I never tried to cross-compile a package against Entware. I assume they must have build instructions on their site.
Tgenius
RMerlin, do you know what version of wpa_supplicant is included in the latest build (if at all)?
RMerlin
Asuswrt-Merlin dev
RMerlin
Asuswrt-Merlin dev
Is there any plans to bump up to a newer build at some point, ie. on the roadmap somewhere?
Not by me. I have no way of testing it to ensure that an upgrade wouldn't break existing functionality.
