Revelstone77
A little background, I was on ATT and was having issues with my work computer ( i work from home via their VPN) where i could connect to the office and do some things, like email. But other services would time out. One trip to the office, i met up with the support folks and they put my laptop on a dirty port to the internet and all was fine. I came home and plugged my laptop into one of the ports on the ATT gateway instead of coming off my AC86U and all was fine, for several years. The problem is, i forgot about that special setup for the work laptop and switched to Xfinity, for more bandwidth and less money and now I'm back to the laptop not working properly again. Today, I factory defaulted the router and put just enough config back in to get connectivity and tried it with no luck. All the other devices in the house work flawlessly. I'm pulling whats left of my hair out over this. My next step is to plug the laptop directly into the cable modem and see if that works. If it does, could I put a switch in between the modem and the router and tap off for the laptop or will the modem not allow two mac addresses?
