Yesterday I installed fresh/new GT6000 (AP) + AX68U (node). It worked great, yesterday! Now I'm noticing that no clients connect to the node, even when 10 to 20 ft away through 1 interior wall. The AP is on the extreme end, of the house 2 floors down (same locations as my prior AC86Us; worked great in same spots)
I even changed a few things trying to get the Node to connect to the devices... no go!?
help please
- Ethernet backhaul
- Node's 2.4g is OFF, AP 2.4g MAC filter for 5 specific devices that require 2.4g. All other devices forced to 5g (this is the same as my prior AC86U setup)
- AP 5G signal strength reduced to Balanced (mid-level, default is 2 level up on Performance)
- Roaming assistant to -60 (default -70)
- 3 devices in Node's line of sight are not connecting to AP (AP signal is far too weak there); not "locking" to AP so seems not a roaming issue?
help please
