Jack Yaz
Part of the Furniture
vnstat2 as well. I suppose i just lost my weekendLooks like Entware just published chrony-nts.
But you gained a...yeah, you’re toast.vnstat2 as well. I suppose i just lost my weekend
jack be like
ntpmerlin develop
chronyc -N authdata
i saw a challenge, ntpmerlin hopefully ready already! vnstat2 has a lot more to consider (did someone say it uses SQLite as the database in v2, what could that lead to?But you gained a...yeah, you’re toast.
marco@RT-AC86U:/tmp/home/root# chronyc -N authdata
Name/IP address Mode KeyID Type KLen Last Atmp NAK Cook CLen
nts.time.nl NTS 1 15 256 47 0 0 8 104
time.cloudflare.com NTS 1 15 256 48 0 0 8 100
time.cloudflare.com NTS 1 15 256 47 0 0 7 100
client side (i.e. stuff connected to your router) should be unaffected. NTS is used for chrony to upstream, local clients will be unaware of NTSJack's enjoying an early weekend. Great work! Will this update on chronyd still answer requests to downstream servers on port 123 and sync itself on 4460 on upstream servers?
Code:marco@RT-AC86U:/tmp/home/root# chronyc -N authdata Name/IP address Mode KeyID Type KLen Last Atmp NAK Cook CLen ========================================================================= nts.time.nl NTS 1 15 256 47 0 0 8 104 time.cloudflare.com NTS 1 15 256 48 0 0 8 100 time.cloudflare.com NTS 1 15 256 47 0 0 7 100
Now only to look for some more NTS ready servers. The default nl.pool.ntp servers error out, saying there's no route to host to port 4460.
pool time.cloudflare.com iburst nts # Anycast - Stratum 3
server netmon2.dcs1.biz iburst nts # Singapore - Stratum 2
server ntp1.glypnod.com iburst nts # San Fransisco - Stratum 2
server ntp2.glypnod.com iburst nts # London - Stratum 2
server ntpmon.dcs1.biz iburst nts # Singapore - Stratum 1
server nts.netnod.se iburst nts # Stockholm, Sweden
server nts.ntp.se iburst nts # Stockholm, Sweden
server nts.sth1.ntp.se iburst nts # Stockholm, Sweden
server nts.sth2.ntp.se iburst nts # Stockholm, Sweden
server nts.time.nl iburst nts # Amsterdam, The Netherlands - Stratum 2
server ptbtime1.ptb.de iburst nts # Braunschweig, Germany - Stratum 1
server ptbtime2.ptb.de iburst nts # Braunschweig, Germany - Stratum 1
server ptbtime3.ptb.de iburst nts # Braunschweig, Germany - Stratum 1
server timemaster.evangineer.net iburst nts # Diemen, The Netherlands
Hold your horses, the weekend ain’t over yet. The man just finished chronyd-nts on his Friday afternoonShould we have this now? I just checked and it looks like my version is 1.18
hey Marco,
good question..
I don’t think there is a public list. Maybe this helps:
ptbnts1.ptb.de (https://pki.pca.dfn.de/dfn-ca-global-g2/pub/cacert/chain.txt)
ptbnts2.ptb.de
ptbnts3.ptb.de
nts.ntp.se:3443
nts.sth1.ntp.se:4460
nts.sth2.ntp.se:4460
time.cloudflare.com:1234
timemaster.evangineer.net:4460
nts1.time.nl:123
ntp1.glypnod.com:4460
ntp2.glypnod.com:4460
ntpmon.dcs1.biz:4460
ntpmon.dcs1.biz:123
netmon2.dcs1.biz:123
the standardized NTS port is now 4460/tcp. So maybe the ports above are now 4460.
ptbnts1.ptb.de is now the official NTS-secured time server of germany and central europe.
have a nice day (⊙ヮ⊙)
-martin-
oh… for germany the new server is: ptbtime1.ptb.de and it uses Lets Encrypt vertificates
ptbtime2.ptb.de and ptbtime3.ptb.de should be online in 1-2 weeks.
time.cloudflare.com is also fine
-martin-
Martin Langer commented on Setting up NTS-Secured NTP with NTPsec.
in response to Marco:
Thanks for the quick reply and the effort you’ve put in NTS.
I hope we can extend NTS for PTP soon (https://datatracker.ietf.org/doc/draft-langer-ntp-nts-for-ptp/)
let me know if you have any questions![]()
-martin-
isn't vnstat entware? So, if vnstat has been upgraded to v2 shouldn't my vnstat show v2? I checked with amtm and it shows up to dateHold your horses, the weekend ain’t over yet. The man just finished chronyd-nts on his Friday afternoon![]()
Unfortunately I get zero's and this:you can check chrony is using NTS by running
The KeyID, Type, and KLen columns should have non-zero values. If they are zero, check the system log for error messages from chronyd.Code:chronyc -N authdata
(source https://fedoramagazine.org/secure-ntp-with-nts/)
Apr 9 18:12:46 chronyd[16150]: Missing NTS support
Code:Apr 9 18:12:46 chronyd[16150]: Missing NTS support
What am I doing wrong?
EDIT: probably this...
http://www.snbforums.com/threads/ntpmerlin-v3-x.68508/post-654666
www.snbforums.com
No...Have you switched to the develop branch and modified chronyd.conf to use NTS?
chronyc -N authdata
time.cloudflare.com NTS 1 15 256 111 0 0 8 100
time.cloudflare.com NTS 1 15 256 110 0 0 8 100
nts.time.nl NTS 1 15 256 111 0 0 8 104
nts.ntp.se NTS 1 15 256 110 0 0 8 100
nts.sth1.ntp.se NTS 1 15 256 109 0 0 8 100
nts.sth2.ntp.se NTS 1 15 256 110 0 0 8 100
ntp2.glypnod.com NTS 1 15 256 111 0 0 6 104
ntp1.glypnod.com NTS 1 15 256 112 0 0 1 104
ptbnts2.ptb.de NTS 1 15 256 112 0 0 6 100
ptbnts3.ptb.de NTS 1 15 256 110 0 0 5 100
ptbtime1.ptb.de NTS 1 15 256 110 0 0 8 100
ntpmon.dcs1.biz NTS 1 15 256 111 0 0 2 104
netmon2.dcs1.biz NTS 1 15 256 111 0 0 0 0
chronyc -N sources
MS Name/IP address Stratum Poll Reach LastRx Last sample
^+ time.cloudflare.com 3 5 177 11 +651us[ +512us] +/- 15ms
^* time.cloudflare.com 3 5 377 6 +1085us[ +947us] +/- 15ms
^- nts.time.nl 2 5 377 37 -2368us[-2508us] +/- 57ms
^+ nts.ntp.se 2 3 377 2 -1514us[-1514us] +/- 26ms
^+ nts.sth1.ntp.se 2 3 377 1 -9816us[-9816us] +/- 34ms
^- nts.sth2.ntp.se 2 3 377 2 -1593us[-1593us] +/- 26ms
^+ ntp2.glypnod.com 2 5 42 86 +497us[ +72us] +/- 20ms
^- ntp1.glypnod.com 2 5 100 109 -2561us[-2969us] +/- 88ms
^+ ptbnts2.ptb.de 1 5 76 77 -764us[-1188us] +/- 20ms
^+ ptbnts3.ptb.de 1 5 324 103 -1116us[-1544us] +/- 21ms
^+ ptbtime1.ptb.de 1 5 17 36 -666us[ -805us] +/- 21ms
^- ntpmon.dcs1.biz 1 5 100 108 +58ms[ +57ms] +/- 165ms
^- netmon2.dcs1.biz 2 5 200 109 +9447us[+9040us] +/- 163ms
chronyc tracking
Reference ID : A29FC801 (time.cloudflare.com)
Stratum : 4
Ref time (UTC) : Fri Apr 09 16:58:57 2021
System time : 0.000108182 seconds slow of NTP time
Last offset : +0.000034297 seconds
RMS offset : 0.000086560 seconds
Frequency : 7.057 ppm slow
Residual freq : -0.001 ppm
Skew : 0.150 ppm
Root delay : 0.026707981 seconds
Root dispersion : 0.000552623 seconds
Update interval : 65.1 seconds
Leap status : Normal
| Thread starter | Title | Forum | Replies | Date |
| M | ntpMerlin ntpMerlin v3.4.12 [2025-Nov-16] - NTP Time Server for AsusWRT Merlin | Asuswrt-Merlin AddOns | 39 | |
ntpMerlin ntpMerlin compatibility with Merlin 3006.102.3 | Asuswrt-Merlin AddOns | 15 |
Welcome To SNBForums
