OpenVPN log question
JDE100
I recently setup an RT-AX88U with Merlin firmware and an OpenVPN server. Everything seems to work okay. I noticed the following in the logs and wondering if this is some type of attack? I do not recognize any of these IPs
Jun 29 03:06:38 ovpn-server1[20619]: 185.200.118.45:52604 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jun 29 03:06:38 ovpn-server1[20619]: 185.200.118.45:52604 TLS Error: TLS handshake failed
Jun 29 04:09:07 ovpn-server1[20619]: 192.241.214.87:43918 TLS Error: reading acknowledgement record from packet
Jun 29 04:10:07 ovpn-server1[20619]: 192.241.214.87:43918 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jun 29 04:10:07 ovpn-server1[20619]: 192.241.214.87:43918 TLS Error: TLS handshake failed
If you use a commonly used port, then you will get random connection attempts hitting it. They aren`t attacking you, they are just scanning random IP addresses, looking for a vulnerable target.
