I am running the latest (3 Oct) build of Asus Merlin. Thank you! It is fun to play with such a powerful router and software. I am currently working on setting up the VPNs to both enable connectivity to my LAN and to secure traffic from public wifi areas. I have Win, Android and iOS devices I want to connect.
There always seems to be a strong roadblock for each of the VPN solutions.
OpenVPN. I am working on getting this running. It appears that non rooted android devices requires TUN, but windows TAP. Thankfully there are two openVPN servers that can be individually configured. TUN uses a different IP subset. How do I route packets between the OpenVPN TUN IP range and my LAN ip range so I can access my LAN over openVPN on android?
PPTP Just Works! unfortunately, it has security issues and does not work with the Always On VPN on android or iOS.
IPsec/L2TP: It appears to be the strong VPN of choice for mobile devices. Always On VPN on android and iOS require it. It seems like most router 3rd party firmwares have a philosophical aversion to it, but it appears to be the VPN of choice for mobile devices for the future whether we like it or not, at least by looking at the OS support by both Apple and Android. Any plans for a GUI to support this VPN solution?
rearden
rearden
