Helllo,
I have two RT-AC66U router configured for OpenVPN.
One is configured as server and the other one for client.
Everything works well but I have no connection between both LANs behind without modifying or disabling the windows firewall on both PC connected to the routers.
IP range config is:
LAN Server 192.168.1.0/24
LAN Client: 192.168.2.0/24
OpenVPN: 10.0.1.0/24
When I disable the windows firewall on the PCs behind the server and client LAN then I can access the shared drives, remotec ontrol the PC etc.
But I do not want to modify the firewalls.
Is it possible via iptables configuration in both routers for SNAT or masquerade to overcome this issue?
I have tried different configs but I anly could get a ping but not shared drives or remote desktop.
Has anyone such a config or any ideas?
IP range config is:
