Password failed after restoration ASUS RT-AC86U
exosteph
Hello,
I have an ASUS RT-AC86U with Merlin firmware 384.13.
I have restore an old save but when i try to connect, password is different as my used password.
Do you know if merlin firmware change password when we use restore ?
Thank's
Stephane
You should configure manually from scratch!
Dont use saved config from different firmware (or router).
  • Like
Reactions: a5m
Hello,
Thank's
Stephane
You can try the default credentials, admin, admin. If you can not login for whatever reason, you will have to reset and start over from scratch. I would also perform a webUI reset with initialize while you are at it, to clear logged data.
OE
  • Like
Reactions: a5m
If your backup was made with an older version, then there is no guarantee that it will be compatible. Some models/versions now encrypt the password.
