Possible bug in Main_TrafficMonitor_last24.asp
sbsnb
When viewing Main_TrafficMonitor_last24.asp toggling the scale dropdown to KB does not show KB.
2022-04-04 10_20_09-ASUS Wireless Router RT-AX86U - Traffic Monitor _ Last 24 Hours - Chromium.png
2022-04-04 10_20_49-ASUS Wireless Router RT-AX86U - Traffic Monitor _ Last 24 Hours - Chromium.png
The Total column still remains in MB units and the measurements have changed from 833.67 down and 32.91 up, to 801.07 down and 31.50 up.
I don't understand the confusion. The total reads 833.67 MB when MB is selected in the dropdown. The total reads 801.07 MB when KB is select in the dropdown. I don't understand what that has to do with the ScaleSize() function.
Also, in the monthly and daily screens the totals are switched to the units in the dropdown.
For MB and higher, the bytes are divided by 1000 to get the desired units. When it’s KB, the bytes get processed by ScaleSize() and get divided by 1024 instead, so the final MB number will appear smaller than when MB is selected outright. It’s an inconsistency in the way unit conversions are handled in the firmware.
But it's not KB. The totals are labeled MB.
There is still the issue that switching the dropdown to MB, GB, or TB changes the totals to the corresponding unit. Only when switched to KB the units are changed to MB instead of KB. This is even inconsistent with the behavior on the Main_TrafficMonitor_daily.asp and Main_TrafficMonitor_monthly.asp.
