Prevent client auto DoH
Xboxsx4life
Hello. I'm running AX86U Pro with latest Merlin release. I've reviewed this thread...
...but I'm still not clear on the difference between "Auto" and "Yes" for the "Prevent client auto DoH" setting when using a DNS filter with DoT.
I currently have DoT enabled in strict mode with Cloudflare's resolvers. And I have Prevent client auto DoH set to "Auto". Should this be changed to "Yes"?
Many Asuswrt settings will display a context help popup if you click on the label:
Just note that DoH depends on a white/black list of hosts...
The way my Prevent auto DoH works is through the APIs used by Windows and Firefox.
In Firefox's case, it won't auto-promote to DoH if the use-application-dns.net hostname resolves to NXDOMAIN or no valid record.
In Windows' case, it works by preventing DDR (Discovery of Designed Resolver) from working:
Thanks for everyone’s responses. Much appreciated. Final follow up question…
How valuable would it be to enable rebind protection? I understand what it does but not sure how much additional security it would add given that it can break certain services from what I’ve read. I’m using DoT in strict mode with ‘DNSSEC’ and ‘validate unsigned replies’ both enabled. Just not sure if it’s worth enabling rebind protection too.
Thanks again.
