Problems on login to webGUI
Jorge Gomes
Hi to all, I'm running version 386_2_4 on an RT AC88U but for some reason, I can't login to it using my browsers on my mac.
I got a broken web pag / webgui.
If I use the Ipad browser I can login.
I clearead all cookies and browser data but with no success.
Any ideas?
Regards.
JG
Look in the browser console window for errors. Whitelist the router URL in any ad-blocker you might use.
Hello, and thanks for the reply.
yes, it seems an issue with my browsers, but Safari doesn't have any add-blockers, like FF or Chrome, and Brave.
Something if very strange indeed.
On FF console I get these errors:
Can't post the code ???
Any Ideas?
Thanks.
It looks like something is blocking javascript.
You may want to check out this site and see if anything applies.
I had a similar problem on my MAC about a month ago. A reboot of the router solved the problem. Problem was however, when I first started experiencing this, I was out of town (I access the system via VPN), so couldn't reboot till I got home. Did check the system on Windows first before I rebooted, and no problem there.
Hi, and thanks,
Yes, the problem is only on my Macbook, at least the one I use most.
If I use a Windows VM, inside Mac (VMw Fusion) all works.
I had the problem prior to the upgrade two days ago, and even after a factory reset and upgrade still happens.
Disable Sophos temporarily if installed.
I was experiencing the same problem ... I put the router's IP on the sophos whitelist and a few refreshes later it's working.
Is this a problem with the firmware or sophos? (I'm guessing it's sophos).
Assuming it is sophos, what can we tell them so it can be fixed permanently?
