Here is the run down of what happened.
I was trying to flash the TM-AC1900 to stock asus firmware.
First I had some trouble getting to the router respond to the firmware restoration utility, so I went ahead and just did the html hack on the web GUI and enabled telnet.
Next I followed one of the youtube video to patch up the cfe file with mac address read out from the new TM-AC1900. I double checked all 3 mac address is changed properly.
Now, here is the thing, that particular video didn't mention anything about I have to patch up the WPS pin as well, so I went ahead flashed the cfe file with just 3 patched address. But I read somewhere that just going to set my WPS pin to 123456 as default.
Right after flashing, I tried to use the holding WPS button method to erase the NVRAM. LED indication seems alright, after holding the WPS button while powering up the router the power button did flash rapidly till I release.
Situation now is the router is booting up fine. The power led is solid, lan port led is correctly indicating the port I am connecting to, and whenever I try to ping the router it did flashes. No other led is on, no wifi, or even the logo at the rear is lit up. I can't ping / telnet / browser to router on 192.168.1.1/192.168.29.1 with either DHCP or manually setting static IP. I am just getting a bogus 164.x.x.x ip assigned to me after an extended period of time. I can still using the reset button to put the router into recovery mode ( at least from the power led blinking state shows), but the restoration utility can't find it, tried to tftp the firmware file to it getting Connect request failed error from powershell. holding WPS to erase NVRAM seems responding alright, at least the led flash rapidly till I release, but whether it actually does anything I am not quiet sure.
So is the this new router is gone for good or there is still some hope? with all the button combo still working and led showing its correct status, I think I am not at the point of no return yet. I have a n66u for couple years now, and actually at times can't do anything to it to get it back online, but after letting it sit out for couple days thing magically came back again.
Any input will be much appreciated!
Regards
G
Regards
G
