Killhippie
'Fixes potential auto Reboot issue' available as of now via the routers firmware update facility, sadly they did not roll the iOS connection fix into this.
Quite... I'm disappointed.'Fixes potential Reboot issue' available as of now via the routers firmware update facility, sadly they did not roll the iOS connection fix into this.![]()
Tell me about itQuite... I'm disappointed.
I did the last update using the router's built in update capability without any problems. I'm curious to know about your problems with this method. Ignorance is not necessary bliss...I prefer to reset before I update and after, but either way doing it via the update file from the site seems always to be less problematic than doing it over the routers own update facility.
NoneI did the last update using the router's built in update capability without any problems. I'm curious to know about your problems with this method. Ignorance is not necessary bliss.![]()
I think they were asking meNone
You should probably ask @NETGEAR Guy as it was a private beta (the branch with the fix was an earlier branch than the current or previous releases and contained none of the newer features, but it is getting rolled into the current production branch with an expected release in June)Ah, this explains what I'm seeing on my iPad Air 2 with the new firmware. I had read that Apple iOS problems were fixed, so this is a very unfortunate regression. They probably did the Apple iOS fix after the branch that this firmware was generated from was taken. Either that or they forgot to roll the Apple fix back onto their development trunk so later branches aren't getting it. Oh well, I'm sure that they'll hear about this one.
Can anyone point me to the latest firmware that has the iOS fix, please? Even if it's a beta?
Thanks!
Welcome To SNBForums
