R7800 QoS issues after update 1.0.1.30
doc octopus
After upgrading, the use of dynamic QoS involves a negative experience with xboxlive, online play becomes impractical due to high latencies that do not occur if the QoS is turned off.
Also point out that manual QoS can not detect the upload bandwidth because the test is failed by the router every time you try.
Which router?
