Preskitt.man
Currently have an AI Mesh system - AC86U is primary and AC68U is mesh node. Long story short, AC68U has bit the dust. I have ordered an AX86U as my new system. Regardless of following alternatives (which I will explain), I presume my first step is from the Web interface of the AC86U, remove the AC68U from the mesh. Then physically remove the device.
I am considering two alternatives setups. Have a medium large house (3100 sq feet), but out of necessity, the primary router is in the front left corner of the house and my wife and her computer, the wifi tv and the kitchen table (where we hang out in the morning is the back right corner of the house. The AC86U can sort of reach those areas, but they are not great - especially considering we depend on WiFi calling on our phones. So my three plans are:
1) Just go with the AX86U - supposed to be better range - it may be good enough. If that is the case, no challenges at all
2) Basically replicate what I currently have, with the AC86U going the back of the house as a mesh node
3) Install the AX86U as an AP node. Different SSID's. That will also take care of the fixed placed devices in the rear which don't need to roam, and hopefully phones (only true roaming device) will always be able to do WiFi on AX86U
4) Or could potentially install AX86U as AP device but with same SSID's - but seems like if I want to go that route, mesh system would be better.
BTW, all phones, laptops and tablets support WiFi 6.
Thoughts
Thoughts
