ChristianTHB
hello,
background story (skip if not interested
currently I use a Netgear R6700v3 with latest FreshTomato firmware on it.
Unfortunately the W-LAN performance isn´t great and QoS looses it´s seetings (so it seems).
Also some settings regarding my Plex Server get lost frequently...very annoing!
Tried DD-WRT too, but it´s almost the same with that...QoS sucks and looses settings...
I used a bunch of WRT54G/GS in the past, so I thought, maybe give Linksys a try with the WRT3200ACM.
Big mistake! stock firmware was useless and with OpenWRT and DD-WRT the 5GHz wasn´t working correctly!
So now I don´t know what I should get.
In the past I had an old Netgear R7000 router with Merlin FW, worked like a charm.
Therefore I thought, maybe a router from Asus is what I need...
Here are my requirements (prioritized):
I found the "RT-AC88U" and "RT-AX82U" that would fit my budget of about 200 Euro.
QoS seems to work very well on Asus devices...or isn´t it?
- QoS
- W-LAN performance/range/stability
- GB Ports (at least 4)
- 3rd party FW support
