Reporting router settings
Mobo1964
I want to factory reset my router and reconfigure it.
Now I'm looking for an possibility to report the complete Settings_RT-AC66U.CFG. (using Asuswrt-Merlin - build 3.0.0.4.374.39)
There are tools which report the WPA settings and the password such as RouterPassView v1.51
http://www.nirsoft.net/utils/router_password_recovery.html
Does anyone know a tool which can be used to report all the settings?
Marco
The CFG file is encoded, so you cannot easily extract anything from it.
Best way would be to plug a USB disk to your router, then use SSH to export all your current settings in a text format, with the following command:
nvram show > /mnt/sda1/settings.txt
Adjust the disk path as needed.
That was what I'm looking for.
