Router/modem speed disparity
Sean Rhodes
I have a Harris docsis cable modem outputting at 120/56 Mb/s up/down speeds. I have my ASUS RT-AC4200 running 384.13_10 firmware, which only has 54/10 Mb/s up/down speeds.
is the loss in speed due to the router hardware limitations, or is the hardware assist speed boost incorrectly configured or not available in this model?
I’d appreciate any advice on this issue
ColinTaylor
Part of the Furniture
"outputting at 120/56 Mb/s up/down speeds" Do you mean down/up?
"RT-AC4200" I have not heard of this model.
Do you have any VPN and/or QoS active? If so try disabling those and testing again.
Sean Rhodes
Not at the moment, QOS essentially kills everything so I have that disabled. I do use VPN, but I had it disabled prior to running the speed test
Jack Yaz
probably a slip of the finger for 3200 :)
Sean Rhodes
It was yes. Also, I think it was a fluke. I ran another couple of tests and there was barely any difference in the speeds. I'm assuming the first test was due to low bandwidth usage when I ran the test
