greggy101
RT-AC68U -3.0.0.4.374.291 available at the main Asus download site
Added:
1. Added Apple time machine feature in USB application.
2. Both NTFS and HFS+ format HDD are supported.
3. Added OpenVPN server.
4. Added OpenVPN/ PPTP/L2TP client.
5. Some devices like set top box, smart TV or Blu-ray player are not able to establish VPN connection. VPN client in router can help these devices to connect to VPN server.
6. Supported HFS+ format HDD
7. Added 2.4GHz beamforming option in advanced settings —> wireless —>professional
8. Added roaming assistant: allow to set the minimum RSSI to disconnect clients and let clients reconnect to Ap with better signal.
Modified:
1. Enhanced FAT32 read/write speed
Fixed:
1. Adjusted 2.4GHz power saving algorithm to fix slow wireless in some special scenarios.
2. Fixed ASMedia 1053E USB 3.0 controller compatibility issue.
3. Fixed IPv6 related issues
4. Fixed quick internet setup UI issues when setup the router by wireless client.
5. Fixed WPS push button related issues.
6. Fixed the security related issues for httpd.
Added:
Modified:
Fixed:
