I have 2 RC-AC68U set up with the latest beta firmware which was a quick fix from release for security. One upstairs one downstairs in a 3 bed house. I have 2 echo speakers and a dot. The dot is upstairs next to my newest 2020 router which is the primary and in the next room is a speaker. Downstairs is the node in dining room connecting on 5ghz with signal strength -54dbm. Along with that is another echo speaker about 10 feet from the node in clear air in the kitchen.
I listen to streaming music on the everywhere group which is all 3 echo devices. This will now and again drop out and my diagnostics lead me to the kitchen speaker. Which is why I got the mesh in the first place. It seems to roaming from downstairs to upstairs then back. This process doesn't seem to be seamless so it drops the stream.
How can I stop the roaming? Roaming is set to -70 the default and I have found the roaming block list which I am now trying and monitoring. Binding the speakers to each router doesn't seem to make any difference. Here is the log entry when the connection drops
Apr 1 16:31:41 roamast: eth2: sta-ap-band-bind deauth [50:dc:**]
Apr 1 16:31:41 roamast: eth2: remove client [50:dc:e7:**] from monitor list
Apr 1 16:31:41 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 50
C:**, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
50
C** is the Kitchen Echo. Any ideas?
50
