my first post, thank you to all who take the time to help out
bought this RT-AC68U in 2016, never had issues (too much) and while I can share a few quirky things, mostly I have been using it successfully with the ASUSWRT firmware (stock).
The current issue that's giving me ulcers is that it's rebooting on its own when something happens. That something is very random, e.g. I start the Netflix client on a Blu-ray player. Or a Win10 laptop connects to the Wi-Fi (2.4 or 5, it doesn't matter)???
I believe it all started with my upgrade from 3.0.0.4.385.20633 to 3.0.0.4.386.41634. Nothing unusual, right? And yet, I noticed that I started losing the Internet connection from time to time. Even called my provider to find out if there is anything wrong on their end.
These are the things I did once I realized it's my issue
1. Reboot numerous times, both the router and the modem from the provider.
2. Reset to factory settings from within the user interface, re-configured it manually after that
3. Reset to factory settings by holding the WPS button and then again, re-configure manually
4. Flash it with Merlin 386.2_2, reset with the WPS button
When one of the those events occur:
1. I lose connection to the user interface (web portal) from my command center PC
) which is wired through a Netgear switch
2. All connected devices lose their connections, wired and wireless
3. When I look at the front of the router, the lights don't show as if it's restarting the usual way. They are lit up as if there is nothing wrong ???
4. A few minutes later, I regain connection to the router's web portal. At that moment, the WAN connection is still being negotiated. Sometimes it connects within 30 seconds, sometimes it takes 5 minutes. The System log clearly shows that the router has rebooted because the uptime is reset and the date is wrong, May 5th, 01:05:02. Once, the Internet connection is restored, the date is set correctly
The setup is very simple, a DSL modem SR501 from the Internet provider, then the "beautiful" creature RT-AC68U, then a single cable from port 2 to a netgear switch. ASIDE from the firmware upgrade, no other changes to anything and that's why I'm focusing on the upgrade. But now that I have moved to Merlin, it doesn't make sense
My next step is to enable SYSLOG on a device somewhere so I can collect proper logs (does that make sense? will this help me with anything?) and if I can't figure it out from the logs, then I will force it into recovery mode and restore the last firmware version that was working fine
If you have any ideas, I'd be forever greatful
MD
MD
