we should see reviews soon I hope?
hi guys
first thing of note is its form factor , surprising in this age of bigger and bigger and bigger monoliths when it comes to wireless router the rt-ac86u believe it or not is almost exactly the same size as its predecessor in the rt-ac68u , this is achieved by running the 4th 5 gig antenna internally to give its the 4 x 4 – 2156M wifi , its the same stand up design as the rt-ac68u also which means its not all that easy to wall mount but its upright design will aid with cooling
Those with the rt-ac68u may not get that rush of getting a new bigger toy but the rt-ac86u is a wolf in sheep's clothing
The web gui is as expected from asus with the addition of the new aiprotect designed to work with both normal clients and IoT devices , slightly revamped gui styling ,
Game boost is also included as it is in the rt-ac88u and rt-ac5300
has both usb 3 and usb 2 ports and its suggested that its usb 3 speeds are very good ( yet to be tested )
the red racing stripes suggest speed and this thing has got it in spades
specs
CPU1: Broadcom BCM4906 (1.8 GHz, 2 cores)
FLA1: 256 MiB (Macronix NAND)
RAM1: 512 MiB (Micron MT41K256M16TW-107
WI1 chip1: Broadcom BCM4366E
WI1 802dot11 protocols: an+ac
WI1 MIMO config: 4x4:4
WI1 antenna connector: U.FL, RP-SMA
WI2 chip1: Broadcom BCM4365E
WI2 802dot11 protocols: bgn
WI2 MIMO config: 3x3:3
WI2 antenna connector: RP-SMA
ETH chip1: Broadcom BCM4906
Switch: Broadcom BCM4906
LAN speed: 10/100/1000
LAN ports: 4
WAN speed: 10/100/1000
WAN ports: 1
just for info the E series broadcom wifi chipset has been proving to be really good coverage wise
pete
note : the data below is tested with the best adapter available and under test conditions , use of lower spec adapters / devices and or poor environmental conditions will give reduced mileage
data throughput for wifi
25 meters pc2 with pce-ac88 ( one end of my house to the other )
5 gig @80mhz ch 157
read 61 MB/s write 40 MB/s rssi -58 sync 585M
2.4 gig @ 20mhz ch1
read 12 MB/s write 12 MB/s rssi -40db sync 192.5M
12 meters next room
5 gig @80mhz ch 157
read 110 MB/s write 86 MB/s rssi -29 sync 1.6G
2.4 gig @ 20mhz ch1
read 25 MB/s write 25 MB/s rssi -25db sync 361M
3 meters same room
5 gig @80mhz ch 157
read 110 MB/s write 107 MB/s rssi -25db sync 1.4G
2.4 gig @ 20mhz ch1
read 25 MB/s write 25 MB/s rssi -25db sync 288.5M
usb 3 testing with
Reducing USB 3.0 interference off
test comp to ethernet on 86u connected at 1Gbps
ntfs
read 110MB/s write 32MB/s
need to check write results
originally posted on whirlpool forums
