RT-AC87U wpa2 enterprise with merlin?
ZFactor
Hi all,
Can anyone with a RT-AC87U confirm whether the Merlin firmware enables WPA2 enterprise? This is not available in the stock ASUS firmware - only WPA/WPA2 personal.
Thanks!
-Z
Mine shows the option under 2.4GHz
I tried flashing latest merlin. Unfortunately, it's only the 2.4GHz band and not 5 GHz that allows WPA2, same as the stock firmware. I really do want WPA2 enterprise on 5 GHz, so I guess I'll use the RT-AC68U instead.
5GHz on the 87U uses a separate Quantenna chip, so it is unlikely that WPA2 will be added (Asus will need to be the ones to add support).
