RT-AX68U Merlin vs. 3.0.0.4.388_24646
escape75
It looks like Asus resurrected the RT-AX68U router by releasing firmware 3.0.0.4.388_24646 ...
I'm wondering though how many things in the Asus firmware are currently patched that would not be patched in Merlin 3004.388.6_2 ?
I'm running the Merlin one at the moment and just wondering about it, but my guess is that 388_24646 is actually not really that new and Merlin might contain most fixes already ?
Thanks!
Bug Fixes and Enhancements:
- Enabled DynDNS and No-IP DDNS to use IPv6.
- Enabled WireGuard Server clients to access the Samba server.
- Enabled the failback function when using the iOS/Android USB backup WAN.
- Improved AiMesh backhaul stability.
- Improved Wireguard performance.
- Improved consistent display of client status on the WireGuard server.
- Improved stability when enabling or disabling the WireGuard server.
- Improved system stability when accessing the WireGuard Server with DMZ enabled.
- Improved memory utilization and fixed an occasional server error when registering DDNS with an app.
- Modified the USB application option text in dual WAN.
- Fixed network map bugs.
- Fixed memory leak issue.
- Fixed v6plus related Issues.
- Fixed ipv6 network service filter not work.
- Fixed the IPsec VPN compatibility issue with Win10.
- Fixed the reboot issue when assigning specific clients in VPN fusion.
- Fixed Client DOM Stored XSS vulnerability.
- Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
- Fixed the problem that the AiCloud app cannot add router on Android 9.
- Fixed the issue where Traffic Analyzer sometimes couldn't record data.
- Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
- Fixed AiMesh preferred AP identification in site survey results.
- Fixed a bug encountered when adding a rule to the network services filter.
- Fine-tuned the description for port status.
- Resolved the issue with login and password changes.
- Resolved the IPSec VPN connection issues.
- Resolved OpenVPN Server TAP Mode Issue.
- Resolved the Instant Guard connection issues.
- Resolved an issue that caused hostname errors in the DDNS service.
- Resolved the ARP response issue, along with the connection issue between the router and the ROG Phone 6 and 7.
- Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node.
Security updates:
- Enabled and supported ECDSA certificates for Let's Encrypt.
- Enhanced protection for credentials.
- Enhanced protection for OTA firmware updates.
- Enhanced protection against SSH brute force attacks.
- Fixed CVE-2022-46871.
- Fixed Client DOM Stored XSS.
- Fixed DoS vulnerabilities in httpd and firewall configuration pages.
- Fixed information disclosure vulnerability.
- Fixed null pointer dereference vulnerabilities.
- Fixed the cfg server vulnerability.
- Fixed FFmpeg vulnerabilities.
- Fixed OpenSSL vulnerabilities.
- Fixed several curl vulnerabilities.
- Fixed CVE-2023-28702 and CVE-2023-28703.
- Fixed an OpenVPN vulnerability categorized as CWE-134.
- Fixed the vulnerability in the logmessage function CVE-2023-35086/ CVE-2023-35087.
- Fixed security issues on the status page.
