RHPT
I've been using an RT-AX88U for 1.5 years and it has worked great until recently. Starting about a week ago, the router constantly drops the connection to the cable modem, and I have to power cycle the router to get it working again. This is happening every couple of hours and is very frustrating (In fact, the router lost connection as I was writing this post and it was only 40 minutes ago that I rebooted the router). The issue isn't with my provider because I am able to use the internet when connected directly to the modem, and I've rebooted my modem as a precaution. I am running the latest stock firmware, 3.0.0.4.388_23748-g50a1620.
I do have one AiMesh node, an RT-AC66U B1, that is hardwired to the AX88U. This is a recent change. Previously, I was using wifi for backhaul connectivity but it wasn't working so great so I ran a cable from the AX88U to the node.
I looked over the log, and I see many, many entries like these, in the hundreds. Is this normal?
Any help would be greatly appreciated. I'm at the point of ditching the Asus altogther
Jul 30 19:24:23 wlceventd: wlceventd_proc_event(662): eth6: Disassoc F8:87:F1 : D2:4A:96, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 30 19:24:23 wlceventd: wlceventd_proc_event(662): eth6: Disassoc F8:87:F1: D2:4A:96, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jul 30 19:24:23 roamast: eth6: disconnect weak signal strength station [f8:87:f1: d2:4a:96]
Jul 30 19:24:23 roamast: eth6: remove client [f8:87:f1:d2:4a:96] from monitor list
Jul 30 19:24:25 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Jul 30 19:24:27 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
Jul 30 19:24:32 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Jul 30 19:24:35 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 100 mbps full duplex
Jul 30 19:24:40 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
