Hello,
I have a question regarding the RT-n66u for a PPTP vpn connection router to router.
I already have an RT-n66u in site A and have its PPTP VPN server running properly. What I am looking for is getting another one to another site B, which will allow outgoing PPTP connections to the router at site A. My existing router is running the stock fw. and I know a VPN client does not yet exist embedded in the stock fw. Could anyone tell me if any of the TomatoUSB builds allows to setup outgoing PPTP vpn connections easily with a GUI (I do not want to deal with scripts etc...)? And how easy would that be?
Lan A (with the existing RT-n66u) is in the US and Lan B is in Europe. Lan B is ADSL-based so it will rely on a separate DSL modem. So far the only routers I have found that can do this are the Draytek's (Vigor series) but their range is not that impressive.
Thanks in advance,
Thanks in advance,
