Script for http filter with time slot
Matt-One
Hello I installed some days ago the gnuton firmware (thx @GNUton for the great firmware full of options and your support) on my dsl-ac68u.
I'm not good to programming and I come here to ask you some help to make a script that can block a website of my interest in certain timeslots
In practice, I would like to block for example only YouTube (or all streaming and entertainment sites if I can't block them individually) to my niece in certain time slots and not 24 hours a day. Is it possible?
Thank you so much :)
Inviato dal mio SM-N950F utilizzando Tapatalk
So no chance to block a website like YouTube for example on a static ip from 14 to 16 of a xyz day?
This is not a DSL specific question.. a different thread would get you more answers.. or just google for something like this:
https://www.snbforums.com/threads/p...te-from-a-specific-computer-via-router.36056/
a firewall rule set within a crontab would be a solution. google may help u.
Thank you again for your reply :)
I googled before, and I found the answer in opendns but I thought a script could be more efficient :) without using or changing other DNS :)
I will take a look at opendns, thank you again :)
So, i can't use the firewall rule to block a website of a static ip (or mac) on my device using shedule time, i don'k know why... So looking on google i found this cru command (on this forum), ok i can't block a specific website like youtube, but i can block all the Streaming and Entertainment sites enabling or disabling the AI Feature at XXX hour of YYY day.
Are this commands corrects? They will match what i need?
cru a filtering-on "0 6 MON-FRI * * [turn AiProtection Parental Controls on]"
cru a filtering-off "0 18 MON-FRI * * [turn AiProtection Parental Controls off]"
DISABLE :
nvram set wrs_app_enabled=0
nvram set wrs_enable=0
service "restart_wrs;restart_firewall"
ENABLE :
nvram set wrs_app_enabled=1
nvram set wrs_enable=1
